SSH and Web management acces of switch from LAN
‎08-17-2017 12:22 PM
Hi there,
I'm new to ExtremeOS, im trying to setup SSH and Web management of an X450a-24t.
I have given the mgmt vlan an ip address.
And i have created a new vlan, vlan 4094 (ManagementVLAN) an ipaddress.
But i cant access either from the lan.
Can help with a step by step guide on how to configure this correctly?
Here is a screen grab of my vlan config.
Name VID Protocol Addr Flags Proto Ports Virtual
Active router
/Total
Default 1 --------------------------------T------------ ANY 0 /26 VR-Default
ManagementVLAN 4094 --------------------------------------------- ANY 0 /0 VR-Default
Mgmt 4095 192.168.155.4 /16 ------------------------- ANY 1 /1 VR-Mgmt
Many thanks,
Peter
Active router
/Total
Many thanks,
Peter
10 REPLIES 10
‎08-17-2017 02:54 PM
Hello Peter,
This is difficult to say. The ports and VLAN assignment is part of the design of the network. The tagging is used to send traffic L2 across VLANs with a common link. This way the other side (Ie. another switch, typically) can know what VLAN that traffic is associated with. You can only have one VLAN untagged per port.
‎08-17-2017 02:46 PM
Hi yes enable web http has been run.
So do i just need to add all of the ports as tagged into the other valns then?
‎08-17-2017 02:32 PM
Also, did you "enable web http/https"?
‎08-17-2017 02:30 PM
The ports are not added into the other VLANs. The VLANs will not become active unless there is an active port added to them.
