SSH and Web management acces of switch from LAN
‎08-17-2017 12:22 PM
Hi there,
I'm new to ExtremeOS, im trying to setup SSH and Web management of an X450a-24t.
I have given the mgmt vlan an ip address.
And i have created a new vlan, vlan 4094 (ManagementVLAN) an ipaddress.
But i cant access either from the lan.
Can help with a step by step guide on how to configure this correctly?
Here is a screen grab of my vlan config.
Name VID Protocol Addr Flags Proto Ports Virtual
Active router
/Total
Default 1 --------------------------------T------------ ANY 0 /26 VR-Default
ManagementVLAN 4094 --------------------------------------------- ANY 0 /0 VR-Default
Mgmt 4095 192.168.155.4 /16 ------------------------- ANY 1 /1 VR-Mgmt
Many thanks,
Peter
Active router
/Total
Many thanks,
Peter
10 REPLIES 10
‎08-17-2017 12:32 PM
Hi Peter,
A couple notes:
Brad
A couple notes:
- The Mgmt vlan is only the mgmt port on the front of the switch.
- There are no ports in the "ManagementVLAN"
- To add a port to "ManagementVLAN" use the following command "configure managementvlan add port
" - The Mgmt vlan is a separate, dedicated, vlan that is intended for out-of-band management of the switch, and doesn't allow IP communication to the rest of the vlans on the switch.
Brad
