I cant enable web interface with my summit x460. I have tried creating Mgmt Vlan with ip 172.16.99.1 / 24 but when im connected using "Management Port" i can't ping 172.16.99.1 or acces web page (i set my laptop ip to 172.16.99.254 / 24). I also run and saved command "enable web http"
* Bud_1-X460.3 # show vlan
Name            VID  Protocol Addr        Flags                Proto  Ports  Virtual
        Active router
        /Total
Default         1    172.16.98.1    /24  ------------------------- ANY    0 /0   VR-Default
Mgmt            4095 --------------------------------------------- ANY    1 /1   VR-Mgmt
v1-KD           10   --------------------------------------------- ANY    9 /9   VR-Default
v3-CCTV         30   192.168.3.254  /24  ------------------------- ANY    7 /9   VR-Default
v4-SCADA        40   10.244.4.254   /24  ------------------------- ANY    1 /3   VR-Default
v99-mgmt        99   172.16.99.1    /24  ------------------------- ANY    1 /1   VR-Default
Flags : (B) BFD Enabled, (c) 802.1ad customer VLAN, (C) EAPS Control VLAN,
        (d) NetLogin Dynamically created VLAN, (D) VLAN Admin Disabled,
        (E) ESRP Enabled, (f) IP Forwarding Enabled,
        (F) Learning Disabled, (i) ISIS Enabled, (L) Loopback Enabled,
        (l) MPLS Enabled, (m) IPmc Forwarding Enabled,
        (M) Translation Member VLAN or Subscriber VLAN,
        (n) IP Multinetting Enabled, (N) Network Login VLAN, (o) OSPF Enabled,
        (O) Flooding Disabled, (p) PIM Enabled, (P) EAPS protected VLAN,
        (r) RIP Enabled, (R) Sub-VLAN IP Range Configured,
        (s) Sub-VLAN, (S) Super-VLAN, (t) Translation VLAN or Network VLAN,
        (T) Member of STP Domain, (V) VPLS Enabled, (v) VRRP Enabled,
Total number of VLAN(s) : 6i have also tried to
