Switch x440t extreme problem with ports
Andrei_Tunes
Hello! I have some problems with some ports of my switch x440t. How can i discover if my ports are failing? exist some command?
thanks!!!
20 REPLIES 20
I upgraded my switch, but not solve my problem... What I don't understand is why the switch don't show me that it have a problem??
Thank you!!
Paul_Russo
Andrei
LLW stands for Limited Lifetime Warranty. LLW is for the Hardware so if there is a physical issue it will be replaced. I would recommend Sumit's suggestion first.
Thanks
P
Thanks again!! You are helping me a lot!
So, i run the diagnostic extended and everything is ok, but my ports 1-9 dosen't work yet. look the diagnostic:
[KSW-SFB-CENAFLOR.1 # run diagnostics extended
Running Diagnostics will disrupt network traffic.
Are you sure you want to continue? (y/N) Yes
SW-SFB-CENAFLOR.2 #
The system is g
Sending SIGKILL to all processes
Requesting system reboot
Extreme Networks
Alternate BootStrap Image
Starting CRC of Default image
Using Default image ...
Extreme Networks
Default BootLoader Image
DRAM Post
Press and hold the to enter the bootrom.
Copyright 2003 - 2012 Extreme Networks, Inc.
Loading EXOS Diagnostics ... | /
Running Image ...Decompressing diagnostics...
Initializing operational diagnostics...
Running Power On Self Test...(Extended mode)
Test i2cenviron - PASS
Test nvram - PASS
Test internal compact flash - PASS
Test sdram - PASS
Test loopback eth - PASS
Test loopback pci - PASS
Test loopback mac interface - PASS
Test loopback phy copper - PASS
Test loopback phy fiber - PASS
Test snake interface - PASS
Test asic0 reg - PASS
Test asic0 mac - PASS
Test asic1 reg - PASS
Test asic1 mac - PASS
Storing diagnostics result into EEPROM.
Diagnostics completed.
Waiting for reboot...Restarting system.
What is happening?
Sumit_Tokle
Contributor
we have seen on EXOS 15.1 and EXOS 15.2 base software version for X440 switch, some ports stops forwarding the traffic at random interval of time. those port never learn mac address. I would suggest to upgrade the switch to EXOS 15.,3.1.4 patch 1-33 and see if you are facing the similar issue.
So, are you think that my equipment have a hardware problem? Why the diagnostic extended can't find nothing?
What I need to do?
Thank you again!!
