Switch x440t extreme problem with ports
Andrei_Tunes
Hello! I have some problems with some ports of my switch x440t. How can i discover if my ports are failing? exist some command?
thanks!!!
20 REPLIES 20
Hey Andrei
This depends on your service level. If you do not have a service level then you can only get the level of code that was out when you ordered your equipment. I would call TAC and see if they can help diagnose the issue it will be the fastest resolve time.
P
Hello! We have on switch the EXOS 15.3.2.11 parch1-2. Maybe I can to upgrate for 15.4... What do you think?
Andrei_Tunes
Thanks to your help!!! The ports are enabled, but doesn't work. Sorry about my ignorance, but what is LLW and HW?
Paul_Russo
running the diagnostics should show any HW issues. If the switch is still in default just do a show vlan default or show default and see if the ports are enabled. they will have a ! if they are disabled.
If they are enabled then I would recommend opening a TAC request. The 440 has LLW that will replace the HW if it is bad.
Thanks
P
Andrei_Tunes
Hi! Some ports of my switch doesn't respond. Even the leds don't light. But, I can't find a command what say something like "Problem in port x". Sorry about my english....
Thank you!
