Switch x440t extreme problem with ports
Andrei_Tunes
Hello! I have some problems with some ports of my switch x440t. How can i discover if my ports are failing? exist some command?
thanks!!!
20 REPLIES 20
Paul_Russo
Hello Andrei
Not sure what problems you are having with the ports but if you look at the stats for TX and RX and you are seeing errors what I would then do is run Extended Diagnostics on the switch using the run diagnostics extended. This will impact the switch so please do it after hours or in a maintenance window.
Thanks
P
