Trouble connecting to Management port with either direct or switched ethernet connection
Tim_Black
New Contributor II
I have a windows 10 host with an ethernet interface (configured with static ip 192.168.1.2/24) that is directly connected to the Management Port of an X440G2-12p-10G4. Both sides of physical connection have their 1G link lights on. Via serial console on this switch, I have set an ip address on the Mgmt vlan of 192.168.1.100/24. But from the windows machine I cannot ping nor telnet the switch at 192.168.1.100. Can you help me diagnose the reason why?
From the windows host, I see:
C:\>ipconfig
Windows IP Configuration
Ethernet adapter VirtualBox Host-Only Network:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::593a:8176:d2a:d8e8%18
IPv4 Address. . . . . . . . . . . : 192.168.56.1
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
Ethernet adapter Ethernet 2:
Link-local IPv6 Address . . . . . : fe80::1c19:e5e6:9b2:4aa5%12
IPv4 Address. . . . . . . . . . . : 192.168.1.2
C:\>ping 192.168.1.100
Pinging 192.168.1.100 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.100:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 172.16.8.1 172.16.8.60 25
127.0.0.0 255.0.0.0 On-link 127.0.0.1 331
127.0.0.1 255.255.255.255 On-link 127.0.0.1 331
127.255.255.255 255.255.255.255 On-link 127.0.0.1 331
172.16.8.0 255.255.255.0 On-link 172.16.8.60 281
172.16.8.60 255.255.255.255 On-link 172.16.8.60 281
172.16.8.255 255.255.255.255 On-link 172.16.8.60 281
192.168.1.0 255.255.255.0 On-link 192.168.1.2 281
192.168.1.2 255.255.255.255 On-link 192.168.1.2 281
192.168.1.255 255.255.255.255 On-link 192.168.1.2 281
192.168.56.0 255.255.255.0 On-link 192.168.56.1 281
192.168.56.1 255.255.255.255 On-link 192.168.56.1 281
192.168.56.255 255.255.255.255 On-link 192.168.56.1 281
224.0.0.0 240.0.0.0 On-link 127.0.0.1 331
224.0.0.0 240.0.0.0 On-link 192.168.56.1 281
224.0.0.0 240.0.0.0 On-link 172.16.8.60 281
224.0.0.0 240.0.0.0 On-link 192.168.1.2 281
255.255.255.255 255.255.255.255 On-link 127.0.0.1 331
255.255.255.255 255.255.255.255 On-link 192.168.56.1 281
255.255.255.255 255.255.255.255 On-link 172.16.8.60 281
255.255.255.255 255.255.255.255 On-link 192.168.1.2 281
Persistent Routes:
I included the VirtualBox Host-Only adapter in the list bc its network is in the ballpark, but I believe this to be irrelevant since, well, it's a different network from the EXOS switch's Mgmt network.
From the switch I see:
* X440G2-12p-10G4.2 # show vlan
Name VID Protocol Addr Flags Proto Ports Virtual
Active router
/Total
Default 1 10.0.0.1 /24 ------------T--------------- ANY 2 /16 VR-Default
Mgmt 4095 192.168.1.100 /24 ---------------------------- ANY 1 /1 VR-Mgmt
* X440G2-12p-10G4.3 # show switch
SysName: X440G2-12p-10G4
SysLocation:
SysContact: [email protected], +1 888 257 3000
System MAC: 00:04:96:9B:9B:E2
System Type: X440G2-12p-10G4
SysHealth check: Enabled (Normal)
Recovery Mode: All
System Watchdog: Enabled
Current Time: Wed Sep 26 00:34:25 2018
Timezone: [Auto DST Disabled] GMT Offset: 0 minutes, name is UTC.
Boot Time: Tue Sep 25 20:32:43 2018
Boot Count: 23
Next Reboot: None scheduled
System UpTime: 4 hours 1 minute 41 seconds
Current State: OPERATIONAL
Image Selected: secondary
Image Booted: secondary
Primary ver: 22.1.1.5
Secondary ver: 21.1.2.14
patch1-2
Config Selected: primary.cfg
Config Booted: primary.cfg
primary.cfg Created by ExtremeXOS version 21.1.2.14
272505 bytes saved on Tue Sep 25 20:32:07 2018
* X440G2-12p-10G4.4 # show mgmt
VLAN Interface with name Mgmt created by user
Admin State: Enabled Tagging: 802.1Q Tag 4095
Description: Management VLAN
Virtual router: VR-Mgmt
IPv4 Forwarding: Disabled
IPv4 MC Forwarding: Disabled
Primary IP: 192.168.1.100/24
IPv6 Forwarding: Disabled
IPv6 MC Forwarding: Disabled
IPv6: None
STPD: None
Protocol: Match all unfiltered protocols
Loopback: Disabled
NetLogin: Disabled
OpenFlow: Disabled
QosProfile: None configured
Flood Rate Limit QosProfile: None configured
Ports: 1. (Number of active ports=1)
Untag: Mgmt-port on Mgmt is active
Any ideas what I am doing wrong here, and what I should check next? Is there some other step to enabling the Mgmt port over ip on these switches?
This is a similar problem to this one, which doesn't seem to have a solution:
https://community.extremenetworks.com/extreme/topics/connectivity-to-a-switch-x440
Thanks,
Tim
p.s. This is an aside from my problem statement, but FWIW I am using the Management port intentionally here because this switch (and many other EXOS switches like it at my company) will be used for network automation in test environments (dynamically turning ports on/off, creating vlans, etc to form various network topologies for the DUTs to be connected to) and:
(a) I want to guarantee the test machines will have dedicated, unfettered access to the switches in the case of botched switch configuration at test runtime, so we have a guaranteed way to reset configuration, and
(b) I want to save a "normal" port by using the Mgmt port, since in some cases we may be using small port count switch variants (like the one in this example) that are like to fill up in the test.
10 REPLIES 10
Tim_Black
New Contributor II
From the comment linked below, I learned that when pinging an outside address from the Mgmt Vlan/VR, you have to use a different form that specifies the Virtual Router name.
Using this proper form, I now get this:
* X440G2-12p-10G4.2 # ping vr "VR-Mgmt" 192.168.1.2
Ping(ICMP) 192.168.1.2: 4 packets, 8 data bytes, interval 1 second(s).
--- 192.168.1.2 ping statistics ---
4 packets transmitted, 0 packets received, 100% loss
round-trip min/avg/max = 0/0/0 msInstead of what I was getting before:
* X440G2-12p-10G4.1 # ping 192.168.1.2
Packet transmit error; Destination unreachable
0 packets transmitted, 0 packets received, 0% loss
round-trip min/avg/max = 0/0/0 msSo now it is claiming to have sent the ICMP packets, so I change my last statement that the problem is with the route on the switch.
[filter_by]=all&topic-reply-list[settings][reply_id]=17783223#reply_17783223]https://community.extre...
Tim_Black
New Contributor II
OK, here's a little more info to narrow down the problem - Since:
  • the ping from the PC to the switch fails with "Request timed out" and
  • the ping from the switch to the PC fails with "Packet transmit error; Destination unreachable"
I'm pretty sure the problem is with the switch not having a route to my PC.
Which brings me back to the question about the error I received trying to delete or change the default route on VR-Mgmt.
Tim_Black
New Contributor II
It would appear that I have followed the official instructions for what I am trying to accomplish, here:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-an-IP-address-on-the-mana...
and here:
https://gtacknowledge.extremenetworks.com/articles/How_To/Getting-IP-connectivity-on-a-EXOS-switch (section titled: IP connectivity to a Switch on the Mgmt VLAN from the same VLAN)
The latter link says to make sure VLAN tagging is correct if you've done everything and still can't ping the Mgmt ip address. So I read the suggested page: https://gtacknowledge.extremenetworks.com/articles/How_To/Understanding-EXOS-VLANS-and-tagged-and-un...
but there is nothing mentioned there about adding ports to the Mgmt vlan or tagging ports on the Mgmt vlan. Furthermore, the former linked page (first in this post) says specificallt:
  • Ports cannot be added or removed to the MGMT VLAN and its tag (4095) cannot be changed
So I'm at a loss for what might need to be done here, and will assume that the problem is on the PC side.
If anyone else can think of a reason why I'm not able to ping the Mgmt VLAN/VR from my PC that is configured on the same network, and directly connected, let me know.
Some ideas for next steps:
  1. check the cable
  2. connect the mgmt port to an isolated switch that is connected to my PC and some other devices, and confirm the PC can talk to the other devices on the same network.
  3. ??
Thanks.
p.s. It appears I may have posted in the wrong forum. Maybe shoulda been in one of the "Technical Discussions" sections. I see some relevant posts which are similar to mine, but neither are exactly trying to directly connect to the Mgmt port. Nevertheless, I'm concerned bc they tend to say "just don't use the Mgmt port":
* https://community.extremenetworks.com/extreme/topics/how-to-connect-the-management-port-to-the-netwo...
* https://community.extremenetworks.com/extreme/topics/recommendation-for-configuration-of-management-...
For reasons I've stated in the p.s. of the OP, I have a valid reason for using the Mgmt port (at least, I think I do).
Tim_Black
New Contributor II
When I try removing the default route assigned for the Mgmt vlan, I get an error:
* X440G2-12p-10G4.7 # configure iproute delete default 192.168.1.1
ERROR: Cannot delete the default route with gateway(192.168.1.1)Does this seem right to you that I cannot remove a default route after setting it?
This is all quite confusing, since I've read in the docs that the Mgmt port is not routable.
Let me know if you have any ideas on what might be wrong here.
Tim_Black
New Contributor II
Thanks Taykin. To your first question:
Does this work on the laptop Ethernet 2 adapter when both the laptop IP and VLAN interface are in the in the 192.168.1.0 network?
I think my original post already answers this question (no), as I've shown that the PC "Ethernet 2" interface is 192.168.1.2/24 and the switch's mgmt vlan and virtual router are both at 192.168.1.100/24.
I didn't mention this in my OP but I did set up a default route for the mgmt vlan, using the command:
configure iproute add default 192.168.1.1 vr VR-MgmtThis results in the following current route on the mgmt vlan:
* X440G2-12p-10G4.2 # sho iproute vr "VR-Mgmt"
Ori Destination Gateway Mtr Flags VLAN Duration
#s Default Route 192.168.1.1 1 UG---S-um--f- Mgmt 0d:22h:2m:35s
#d 192.168.1.0/24 192.168.1.100 1 U------um--f- Mgmt 0d:22h:2m:36sThe reason I used 192.168.1.1 when setting up the default route before was that I had originally set the switch's ip to 192.168.1.1. I have since changed it to the current address, thinking the problem may have been an ip collision with another machine on the network (a VM guest was using that .1 originally, but now is using a unique ip addr).
Per the section titled "IP connectivity to a Switch on the Mgmt VLAN from the same VLAN" on this page:
I believe I do NOT even need the default route set up for the mgmt vlan/vr, since right now I'm just trying a direct connection, and my PC is on same network as the mgmt vlan (logically and physically).
For this reason, I will experiment with removing the default route for VR-Mgmt.
However, I do not see why this default route I have set up for the VR-Mgmt would prevent ip connectivity, since both routes in my table indicate to use the Mgmt vlan.
Let me know if you can provide any further assistance.
