Trouble connecting to Management port with either direct or switched ethernet connection
Tim_Black
New Contributor II
I have a windows 10 host with an ethernet interface (configured with static ip 192.168.1.2/24) that is directly connected to the Management Port of an X440G2-12p-10G4. Both sides of physical connection have their 1G link lights on. Via serial console on this switch, I have set an ip address on the Mgmt vlan of 192.168.1.100/24. But from the windows machine I cannot ping nor telnet the switch at 192.168.1.100. Can you help me diagnose the reason why?
From the windows host, I see:
C:\>ipconfig
Windows IP Configuration
Ethernet adapter VirtualBox Host-Only Network:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : fe80::593a:8176:d2a:d8e8%18
IPv4 Address. . . . . . . . . . . : 192.168.56.1
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
Ethernet adapter Ethernet 2:
Link-local IPv6 Address . . . . . : fe80::1c19:e5e6:9b2:4aa5%12
IPv4 Address. . . . . . . . . . . : 192.168.1.2
C:\>ping 192.168.1.100
Pinging 192.168.1.100 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.100:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 172.16.8.1 172.16.8.60 25
127.0.0.0 255.0.0.0 On-link 127.0.0.1 331
127.0.0.1 255.255.255.255 On-link 127.0.0.1 331
127.255.255.255 255.255.255.255 On-link 127.0.0.1 331
172.16.8.0 255.255.255.0 On-link 172.16.8.60 281
172.16.8.60 255.255.255.255 On-link 172.16.8.60 281
172.16.8.255 255.255.255.255 On-link 172.16.8.60 281
192.168.1.0 255.255.255.0 On-link 192.168.1.2 281
192.168.1.2 255.255.255.255 On-link 192.168.1.2 281
192.168.1.255 255.255.255.255 On-link 192.168.1.2 281
192.168.56.0 255.255.255.0 On-link 192.168.56.1 281
192.168.56.1 255.255.255.255 On-link 192.168.56.1 281
192.168.56.255 255.255.255.255 On-link 192.168.56.1 281
224.0.0.0 240.0.0.0 On-link 127.0.0.1 331
224.0.0.0 240.0.0.0 On-link 192.168.56.1 281
224.0.0.0 240.0.0.0 On-link 172.16.8.60 281
224.0.0.0 240.0.0.0 On-link 192.168.1.2 281
255.255.255.255 255.255.255.255 On-link 127.0.0.1 331
255.255.255.255 255.255.255.255 On-link 192.168.56.1 281
255.255.255.255 255.255.255.255 On-link 172.16.8.60 281
255.255.255.255 255.255.255.255 On-link 192.168.1.2 281
Persistent Routes:
I included the VirtualBox Host-Only adapter in the list bc its network is in the ballpark, but I believe this to be irrelevant since, well, it's a different network from the EXOS switch's Mgmt network.
From the switch I see:
* X440G2-12p-10G4.2 # show vlan
Name VID Protocol Addr Flags Proto Ports Virtual
Active router
/Total
Default 1 10.0.0.1 /24 ------------T--------------- ANY 2 /16 VR-Default
Mgmt 4095 192.168.1.100 /24 ---------------------------- ANY 1 /1 VR-Mgmt
* X440G2-12p-10G4.3 # show switch
SysName: X440G2-12p-10G4
SysLocation:
SysContact: [email protected], +1 888 257 3000
System MAC: 00:04:96:9B:9B:E2
System Type: X440G2-12p-10G4
SysHealth check: Enabled (Normal)
Recovery Mode: All
System Watchdog: Enabled
Current Time: Wed Sep 26 00:34:25 2018
Timezone: [Auto DST Disabled] GMT Offset: 0 minutes, name is UTC.
Boot Time: Tue Sep 25 20:32:43 2018
Boot Count: 23
Next Reboot: None scheduled
System UpTime: 4 hours 1 minute 41 seconds
Current State: OPERATIONAL
Image Selected: secondary
Image Booted: secondary
Primary ver: 22.1.1.5
Secondary ver: 21.1.2.14
patch1-2
Config Selected: primary.cfg
Config Booted: primary.cfg
primary.cfg Created by ExtremeXOS version 21.1.2.14
272505 bytes saved on Tue Sep 25 20:32:07 2018
* X440G2-12p-10G4.4 # show mgmt
VLAN Interface with name Mgmt created by user
Admin State: Enabled Tagging: 802.1Q Tag 4095
Description: Management VLAN
Virtual router: VR-Mgmt
IPv4 Forwarding: Disabled
IPv4 MC Forwarding: Disabled
Primary IP: 192.168.1.100/24
IPv6 Forwarding: Disabled
IPv6 MC Forwarding: Disabled
IPv6: None
STPD: None
Protocol: Match all unfiltered protocols
Loopback: Disabled
NetLogin: Disabled
OpenFlow: Disabled
QosProfile: None configured
Flood Rate Limit QosProfile: None configured
Ports: 1. (Number of active ports=1)
Untag: Mgmt-port on Mgmt is active
Any ideas what I am doing wrong here, and what I should check next? Is there some other step to enabling the Mgmt port over ip on these switches?
This is a similar problem to this one, which doesn't seem to have a solution:
https://community.extremenetworks.com/extreme/topics/connectivity-to-a-switch-x440
Thanks,
Tim
p.s. This is an aside from my problem statement, but FWIW I am using the Management port intentionally here because this switch (and many other EXOS switches like it at my company) will be used for network automation in test environments (dynamically turning ports on/off, creating vlans, etc to form various network topologies for the DUTs to be connected to) and:
(a) I want to guarantee the test machines will have dedicated, unfettered access to the switches in the case of botched switch configuration at test runtime, so we have a guaranteed way to reset configuration, and
(b) I want to save a "normal" port by using the Mgmt port, since in some cases we may be using small port count switch variants (like the one in this example) that are like to fill up in the test.
10 REPLIES 10
Ty_Izzet
Tim,
Does this work on the laptop Ethernet 2 adapter when both the laptop IP and VLAN interface are in the in the 192.168.1.0 network? We want to ensure both IPs are reachable within the same subnet first.
If so, you might need to configure a route on the switch for vr-mgmt to reach the other network:
configure iproute add default vr "VR-Mgmt"
You can confirm the routes using
show iproute
