Updates for 8800 module
‎07-18-2016 02:41 PM
Hi everybody) can you please answer a question. I am not a regular user of these devices, but I need to know how to make latest update for them, I bought G48Tc 41517 Black Diamond 8800 48-Port on ebay, should I pay for any licenses for updates, or i just connect it and it updates automatically? Does my location matter, because I am writing from Republic of Kazahstan?
Sincerely,
Zhantuar Note: This conversation was created from a reply on: BD8800 latest stable XOS.
Sincerely,
5 REPLIES 5
‎07-19-2016 03:32 AM
Thank you I hope everything will work out well ))
Hi Vyacheslav, I'll send you Zhantuar's email address so that you two can connect.
Hi Zhantuar,
Glad to start contact with you!
I am responsible for Extreme sales in Kazakhstan.
Could you please send serial number of your line card, so we could check current status.
Thanks in advance,
Vyacheslav
+7 701 704 21 91
Thanks in advance,
Vyacheslav
+7 701 704 21 91
‎07-18-2016 04:22 PM
Also want to add this... do a run diagnostics extended on that blade after it is upgraded and running. This should not affect any services other than a bit of a load on the cpu's in your management card. This will show you if the card has any hardware issues.
Also be aware that putting a "C" card in a newer chassis when either carrier cards or msm-128 cards will downgrade the performance capabilities of the whole chassis to that older card.. If you have like or older cards already then ignore this part 
