Upgrade from 15.X to 21.X Questions
Ken_Tucker
I am adding another stack at one of our locations. The new switches used in the new stack our running 21.1.1.4 patch1-2. The other two stacks at the location are running 15.6.2.12 patch1-6, and 15.5.3.4 patch1-6. I would like to upgrade the XOS in the other stacks during the outage, to the same version as the new stack (21.1.1.4 patch1-2), or higher if you recommend another version.
My questions are:
1. Will the new version need to be installed on each stack slot, or just once to the stack. Will each node need to be rebooted separately, or as a whole stack?
2. Are there any known issues upgrading from the above versions to the new one? There are no special configurations in the switches, just VLANs and IP forwarding. On stack is a transit node in an EAPS ring.
3. SSH is installed and enabled, SSH used to be a separate download and install. Since it is now part of the XOS in version 21.X, are there any additional steps, or will it be enabled from the existing configuration? Will a new key need to be generated after the reboot?
4. If there are issues that we are unable to resolve during our outage window, are there, or will there be, any issues reverting to the currently running XOS?
11 REPLIES 11
I would recommend always going with the latest patch available. They do not add any new features in the patches and they all should be fixes.
Patrick_Voss
Hello Ken,
1. No you can treat a stack like it is a standalone. They can be rebooted as a whole.
2. Not that we have seen.
3. SSH should remain enabled. You can check this through the "show management" command. If not then you can just enable ssh to get it running.
4. You should not run into any issue reverting.
Please let us know if you have any questions.
The upgrade method I'd recommend is to save your initial config in 2 separate files. That way a rollback will be possible with an unmodified config file.
As already mentioned by Patrick, if you create a new account or if you change the password to "admin" then you will face this issue when downgrading from 21.x to 15.7 or earlier releases.
I would recommend you to setup the failsafe account anyway.
Yes. This issue was related to newly created accounts.
