USB drive doesn't mount until switch is rebooted
‎04-08-2015 04:40 AM
Hi, all!
Is any body has a problem - that USB-flash can't mount?
USB mount normally only after reboot switch. Note: This conversation was created from a reply on: Failed to download image - Error: File could not be unwrapped.
7 REPLIES 7
‎04-13-2015 10:27 AM
I have seen this issue when you update from say version 12.x to 15.x - turned out in our case if you look at the flash drives that we used they did not actually have a partition (believe it or not) created and the only way we could tell is if we used disk utility on the mac. There have been a few times where the mfg of the stick seems to make a big difference as well. If you delete and re-add partition using disk manger it has solved it for me 100% of the time.
‎04-08-2015 01:04 PM
HI,
I used USB to upgrade some X460, X670 and X770. I used a Sandisk USB (4GB) in fat 32.
You can use the command:
ls /usr/local/ext
to see the file on the USB.
I don't need to restart the switch to see the USB KEY.
Emmanuel
ls /usr/local/ext
Emmanuel
‎04-08-2015 12:20 PM
Hi Alexandr,
If you can give me some more information, I'll check it out in the lab.
What model switch are you using?
File system of the USB drive?
EXOS Version?
-Drew
EXOS Version?
-Drew
Hi, Drew!
First of all - thanks for help!!!
I can't "catch" this problem.
May be main reason - that USB-flash-drive was in NTFS format?!?!?!
Thank you!
Thank you!
