I have seen this issue when you update from say version 12.x to 15.x - turned out in our case if you look at the flash drives that we used they did not actually have a partition (believe it or not) created and the only way we could tell is if we used disk utility on the mac. There have been a few times where the mfg of the stick seems to make a big difference as well. If you delete and re-add partition using disk manger it has solved it for me 100% of the time.
Hi Alexandr,
If you can give me some more information, I'll check it out in the lab.
What model switch are you using?
File system of the USB drive?
EXOS Version?
