USB drive doesn't mount until switch is rebooted
‎04-08-2015 04:40 AM
Hi, all!
Is any body has a problem - that USB-flash can't mount?
USB mount normally only after reboot switch. Note: This conversation was created from a reply on: Failed to download image - Error: File could not be unwrapped.
7 REPLIES 7
‎04-08-2015 12:20 PM
Hi Alexandr, We tested this in 15.3 and 15.7 on an X460 with a FAT32 formatted drive. The flash drive was inserted and removed 5-10 times and we were consistently able to
code:
without any problems on each attempt. I'm not sure what we may be doing differently. If you come up with something, let me know! We'll test and see if we can get it figured out.ls memorycard
Thanks, I'll ask someone on our lab team to check it out.
Hi, Drew!
Trying X460 switches.
NTFS, FAT
Different EXOS versions.
Main problem that USB can mount 5 times, but 6 time - not.
There is no possibility to "catch" this problem.
Thank you!
NTFS, FAT
Thank you!
