Virtual XOS killing ESX host CPU
Konstantin_Mikh
After initial install and configuration of the vSummit, VM stays at around 60-100Mhz host CPU usage but after about 3min sitting idle, CPU utilization jumps to 3GHz+ and in many cases maxes out Host CPU resources.
Extreme VM performance becomes sluggish and in many cases CLI freezes.
Tested on multiple hosts in the Datacenter with the same outcome.
No other VMs on the hosts (Linux, Windows, Juniper, Fortinet, Cisco, Checkpoint, Avaya) produce the same issue.
Anyone experienced this behavior and if yes, is there a fix/workaround for it?
Specs:
Extreme vXOS ver 16.1.2.14 - same issue with earlier releases.
VMWare vSphere 5.5 with latest patches.
CPU: Xeon 3.2GHz E3-v1225 - 4 Cores
Thank you.
11 REPLIES 11
Konstantin_Mikh
Mem: 221472K used, 32364K free, 0K shrd, 51284K buff, 56156K cachedCPU: 0.3% usr 0.6% sys 0.0% nic 14.9% idle 0.0% io 0.0% irq 84.1% sirq
Load average: 26.60 27.59 25.90 14/178 2034
PID PPID USER STAT RSS %MEM CPU %CPU COMMAND
1650 1 root S 1480 0.5 0 27.1 ./nodemgr
4 2 root RW< 0 0.0 0 11.5 [ksoftirqd/0]
1376 1 root S 2488 0.9 0 7.9 /exos/bin/epm -t 40 -f /exos/config/epmrc -d /exos/config/epmdprc
1664 1 root S 3096 1.2 0 6.9 ./fdb
1700 1 root S 2072 0.8 0 1.6 ./r.png
1762 1 root S 2460 0.9 0 0.6 ./isis
1688 1 root S 8668 3.4 0 0.3 ./dcbgp
2027 1 root S 8364 3.2 0 0.3 ./dcbgp -v 3
1678 1 root S 2096 0.8 0 0.3 ./esrp
1642 1 root S 1368 0.5 0 0.3 ./ds
1648 1 root S < 17312 6.8 0 0.0 ./hal
1652 1 root S 13288 5.2 0 0.0 ./cliMaster
2018 1 root S 8328 3.2 0 0.0 ./dcbgp -v 4
1708 1 root S 5444 2.1 0 0.0 ./netTools
1658 1 root S 4860 1.9 0 0.0 ./snmpSubagent
1827 1 root S 4664 1.8 0 0.0 ./policy
1737 1 root S 4636 1.8 0 0.0 ./xmld
1656 1 root S 3900 1.5 0 0.0 ./snmpMaster
1766 1 root S 3868 1.5 0 0.0 ./idMgr
1644 1 root S 3772 1.4 0 0.0 ./emsServer
1660 1 root S 3596 1.4 0 0.0 ./aaa -t random
1684 1 root S 3156 1.2 0 0.0 ./mcmgr
1682 1 root S 3080 1.2 0 0.0 ./rtmgr update
1662 1 root S 3016 1.1 0 0.0 ./vlan
1702 1 root S 2940 1.1 0 0.0 ./pim
2021 1 root S 2856 1.1 0 0.0 ./ospf -v 3
1692 1 root S 2820 1.1 0 0.0 ./ospf
2012 1 root S 2816 1.1 0 0.0 ./ospf -v 4
1706 1 root S 2804 1.1 0 0.0 ./acl
1722 1 root S 2552 1.0 0 0.0 ./etmon
1768 1 root S 2496 0.9 0 0.0 ./vmt
1694 1 root S 2480 0.9 0 0.0 ./ospfv3
1696 1 root S 2436 0.9 0 0.0 ./rip
1654 1 root S 2428 0.9 0 0.0 ./cfgmgr
1680 1 root S 2332 0.9 0 0.0 ./stp
1764 1 root S 2268 0.8 0 0.0 ./dot1ag
1788 1 root S 2264 0.8 0 0.0 ./erps
1676 1 root S 2196 0.8 0 0.0 ./eaps
1674 1 root S 2192 0.8 0 0.0 ./lacp
1710 1 root S 2176 0.8 0 0.0 ./netLogin
1770 1 root S 2104 0.8 0 0.0 ./vsm
1690 1 root S 2076 0.8 0 0.0 ./msdp
Jeremy_Gibbs
Contributor
What is using the CPU on the xos switch? Run "top" to find out. Post the top processes.
