x440 gbic issues
x440 gbic issues
Luis_Mendes
Contributor
Issues with gbic 10gb, the same gbic works on others model (x450-g2).
Slot-2 Stack.6 # debug hal show optic-info slot 2 port 28
Port 28
SFP or SFP+: SFP
Signal: not present
TX Fault: no
SFP/SFP+ Vendor: 7/ot
SFP/SFP+ Part Number: S+85DLC03D
SFP/SFP+ Serial Number: STTS5
SFP/SFP+ Manufacture Date: 07
SFP/SFP+ Type: SFP/SFP+
Connector: LC
GE Compliance: UNKNOWN (0x0)
Wavelength: 815
I upgrade the firmware for last version, but the same message, its occurs on 2 x440-g2 24t.
24 REPLIES 24
Stachal
New Contributor III
X460-24t/x/p Alternate Stacking
Alternate Stack Port 1 = S1 (29)
Alternate Stack Port 2 = S2 (30)
Stachal
New Contributor III
Have you configured them as alternate stacking ports?
    Confirm all switches are running same software version on the same partition. show version Confirm license level are the same on all switches. show license Configure stacking-support on all switches. Note, a reboot is required for the changes to take effect. configure stacking-support stack-port all selection alternate Connect all stacking cables. Type show stacking command and confirm all nodes are seen in stack topology. If not seen, type show stacking detail confirm all stack nodes are using the same stacking protocol (ie. standard or enhanced). Change stacking protocol on stack nodes if needed. configure stacking protocol enhanced /standard Type configure stacking easy-setup from the console of the switch we would like to take mastership role. Once rebooted issue show stacking and confirm all nodes take a stacking role.
Yes, is this model, but i can use this port for stack without license. If i connect the same gbic(10g) in any other model, the gbic is recognized.. If i put the other gbic (1g), is recognized in the same port of x440-g2
Wesley_Braunber
I am having a similar issue with 440s. The same GBIC will work in a 440-P but not in a 440-T
Stachal
New Contributor III
switch1# sho switch
SysName: switch1
SysLocation:
SysContact: [email protected], +1 888 257 3000
System MAC: **:**:**:**:**:**
System Type: X440-8t
These are the Models and port configurations for the X450
Summit X440-8t
8 x 10/100/1000BASE-T (RJ45) ports
4 x 100/1000BASE-X (SFP) unpopulated ports
2 x SummitStack
1 x Serial (console port) and 1 x 10/100BASE-T out-of-band management port
Summit X440-8p
8 x 10/100/1000BASE-T PoE-plus(RJ45) ports
2 x SummitStack
Summit X440-24t
24 x 10/100/1000BASE-T (RJ45) – 4 ports are combo ports
4 x 100/1000BASE-X (SFP) unpopulated combo ports
2 x SummitStack
1 x Redundant Power Supply connector
Summit X440-24tDC
2 x SummitStack
2 x SummitStack
1 x DC PSU
Summit X440-24p
24 x 10/100/1000BASE-T PoE-plus(RJ45) – 4 ports are combo ports
4 x 100/1000BASE-X (SFP) combo ports
2 x SummitStack
1 x Serial (console port ) and 1 x 10/100BASE-T out-of-band management port
Summit X440-24x
24 x 100/1000BASE-X (SFP) unpopulated ports – 4 ports are combo ports
4 x 10/100/1000BASE-T (RJ45) combo ports
2 x SummitStack
Summit X440-48t
48 x 10/100/1000BASE-T (RJ45) – 4 ports are combo ports
2 x SummitStack
Summit X440-48tDC
2 x SummitStack
1 x DC PSU
Summit X440-48p
48 x 10/100/1000BASE-T PoE-plus(RJ45) – 4 ports are combo ports
2 x SummitStack
Summit X440-24t-10G
2 x 10GBASE-X SFP+ (1G/10G dual speed) unpopulated
Summit X440-24p-10G
Summit X440-24x-10G
Summit X440-48t-10G
48 x 10/100/1000BASE-T (RJ45) – 2 ports are combo ports
2 x 100/1000BASE-X (SFP) unpopulated combo ports
Summit X440-48p-10G
48 x 10/100/1000BASE-T PoE-plus(RJ45) – 2 ports are combo ports
2 x 100/1000BASE-X (SFP) combo ports
