I've been running into a lot of problems with poe devices that are class4 and require PoE+. I have VoIP phones and Wireless AP (802.11AC) that aren't getting the correct amount of power. I have lldp enabled on the port with the AP (enable lldp port 1:3). Is there any known issues with PoE+ that anyone has seen? I fixed (at least I believe it has been fixed) our phone issue by telling the phones (cisco) to not use power negotiation. However I can't do it with the APs (Meraki MR34). Slot-1 is x460 Slot-2 and 3 are both x440 Slot-1 DemoStack.3 # sho version Slot-1 : 800324-00-12 1339N-44663 Rev 12.0 BootROM: 2.0.1.7 IMG: 15.4.1.3 Slot-2 : 800474-00-10 1343N-42635 Rev 10.0 BootROM: 2.0.1.7 IMG: 15.4.1.3 Slot-3 : 800474-00-11 1350N-40109 Rev 11.0 BootROM: 2.0.2.1 IMG: 15.4.1.3 Slot-4 : Slot-5 : Slot-6 : Slot-7 : Slot-8 : SS-B-1 : 800384-00-01 1327N-40559 Rev 1.0 Slot: Slot-1 * Slot-2 ------------------------ ------------------------ Current State: MASTER BACKUP (In Sync) Image Selected: primary primary Image Booted: primary primary Primary ver: 15.4.1.3 15.4.1.3 patch1-10 patch1-10 Secondary ver: 15.3.2.11 15.3.2.11 Config Selected: primary.cfg Config Booted: primary.cfg
