XOS 15.7.1.4 mvrp between BD8806 and SUMMIT X460-G2-48t-10GE4
‎06-09-2015 03:40 PM
just testing mvrp between
3 SUMMIT X460-G2-48t-10GE4 configured as a stack
and
1 BD8806 MSM-48c 10G8Xc
The Summit X stack is connected to BD8806 via a 10GE port.
On the BD8806:
create vlan test
configure test tag 500
configure vlan test add ports 6:2 tagged
configure mvrp tag 500 ports 6:2 registration normal
configure mvrp tag 500 ports 6:2 transmit on
configure mvrp vlan auto-creation on
configure mvrp vlan registration normal
enable mvrp ports 6:2
enable mvrpOn the SUMMIT X stack:
create vlan test
configure vlan test add ports 2:49 tagged
configure mvrp tag 500 ports 2:49 registration normal
configure mvrp tag 500 ports 2:49 transmit on
enable mvrp ports 2:49
enable mvrp
create vlan mvrptest
configure mvrptest tag 200
configure vlan mvrptest add ports 2:49 tagged
However, a show vlan on BD8806 doesn't show mvrptest.
Any hints would be appreciated.
Thank you
antonio
and
On the BD8806:
create vlan test
create vlan test
enable mvrp
Thank you
antonio
28 REPLIES 28
‎06-09-2015 07:15 PM
correct.
I have double-checked that internally.
with a port in it (even disabled) other than mvrp transmitting ports.
is it correct?
thank you
antonio
is it correct?
thank you
antonio
‎06-09-2015 07:13 PM
Antonio,
Are the two switches connected through the correct ports?
show edp port all should show you through which ports the switches see each other.
no, it's not
is that port a LAG ?
