XOS 15.7.1.4 mvrp between BD8806 and SUMMIT X460-G2-48t-10GE4
‎06-09-2015 03:40 PM
just testing mvrp between
3 SUMMIT X460-G2-48t-10GE4 configured as a stack
and
1 BD8806 MSM-48c 10G8Xc
The Summit X stack is connected to BD8806 via a 10GE port.
On the BD8806:
create vlan test
configure test tag 500
configure vlan test add ports 6:2 tagged
configure mvrp tag 500 ports 6:2 registration normal
configure mvrp tag 500 ports 6:2 transmit on
configure mvrp vlan auto-creation on
configure mvrp vlan registration normal
enable mvrp ports 6:2
enable mvrpOn the SUMMIT X stack:
create vlan test
configure vlan test add ports 2:49 tagged
configure mvrp tag 500 ports 2:49 registration normal
configure mvrp tag 500 ports 2:49 transmit on
enable mvrp ports 2:49
enable mvrp
create vlan mvrptest
configure mvrptest tag 200
configure vlan mvrptest add ports 2:49 tagged
However, a show vlan on BD8806 doesn't show mvrptest.
Any hints would be appreciated.
Thank you
antonio
and
On the BD8806:
create vlan test
create vlan test
enable mvrp
Thank you
antonio
28 REPLIES 28
‎06-09-2015 06:31 PM
here are my EXOS versions
on BD8806: 15.7.1.4 v1571b4
on SUMMIT X: 15.7.1.4 v1571b4-patch1-2
thank you
antonio
thank you
antonio
ok, I'll be back to you tomorrow, thank you
‎06-09-2015 06:18 PM
hi,
no I don't.
there are just "default" and "mgmt" vlans
antonio
no I don't.
antonio
‎06-09-2015 05:49 PM
do you see a SYS_VLAN_0200?
