Problem VRRP with VLAN.
Luis_Bernal
New Contributor II
Greetings.
I have two VRRP equipment S6, regarding VRRP configuration is as follows:
- Router 1:
set gvrp disable
set spantree stpmode none
interface vlan 1
vrrp create 1 v2-IPv4
vrrp address 1 10.18.4.250
vrrp priority 1 200
vrrp enable 1
interface vlan 2
vrrp address 1 10.18.5.254
vrrp priority 1 200
vrrp enable 1
interface vlan 10
vrrp address 1 10.18.10.254
vrrp priority 1 200
vrrp enable 1
interface vlan 31
vrrp address 1 10.18.31.254
vrrp priority 1 200
vrrp enable 1
- Router 2:
set gvrp disable
interface vlan 1
vrrp address 1 10.18.4.249
vrrp priority 1 50
vrrp enable 1
interface vlan 2
vrrp address 1 10.18.5.253
vrrp priority 1 50
vrrp enable 1
interface vlan 10
vrrp address 1 10.18.10.253
vrrp priority 1 50
vrrp enable 1
interface vlan 31
vrrp address 1 10.18.31.253
vrrp priority 1 50
vrrp enable 1
By doing tests on the operation of VRRP do the following:
Connect the links to the "switch A" and works well on VVRP. The problem is when I connect to a second switch "switch B and switch C" where the connection on my device VLAN 2 fails.
What I can do that would generate this problem ?.
Thank you very much!.
5 REPLIES 5
PARTHIBAN_CHINN
Contributor
Could you change yo normal triangular topology with two core switches running vrrp And one edge switch . Stp used for l2 loop prevention What is the model number of core switches . There are many solutions available Ex mlag , EAPS
