07-12-2024 01:09 PM
Has anyone had any luck using the Extreme-Dynamic-Client-Assignments VSAs to send back attributes for VLAN assignment on Fabric Switches?
I've tried every variation and my switches will not accept it. I am using XMC/XIQ-SE to send back the following. Is my syntax wrong, the only thing the switch takes is the REAUTH value.
Extreme-Dynamic-Client-Assignments='create=vlan, pv=108, vni=108100, ev=0;'
Extreme-Dynamic-Config=REAUTH
show eapol sessions neap verbose
Command Execution Time: Fri Jul 12 16:08:40 2024 EDT
Non-Eap Oper Status Verbose
PORT MAC STATE VLAN PRI Flex-UNI I-SID NON-EAP VLAN:I-SID ACL ACEs DYN RADIUS DYNAMIC
NUM ID Enable SOURCE AUTH MHSA SETTINGS
1/47 AA:BB:CC:DD:EE:FF authenticated N/A 0 true n/a radius FALSE REAUTH
Total Number of NEAP Sessions: 1
PORT MAC DYNAMIC VLAN ATTRIBUTES
NUM CREATE PV SV I-SID EV VLAN NAME I-SID NAME MVPN I-SID
Solved! Go to Solution.
07-15-2024 06:36 AM
Thank you both for your input and help. It was unfortunately something entirely different as I am running an old version of XMC (I know, I know). I needed to add the VSA (Extreme-Dynamic-Client-Assignments) to the appropriate dictionary file. I conducted a PCAP and noticed XMC wasn't even sending the VSA to the switch whatsoever. After making the adjustments following this article all is well - https://extreme-networks.my.site.com/ExtrArticleDetail?an=000080821
06-09-2025 11:12 PM
You need to use radius accounting for that. It has to be configured on both Extreme Control in switch config, and on switch itself by configuring radius accounting server(s).
