12-07-2022 02:56 PM
Here is the path I want to have for a video multicast. So using IGMP, and this is L2 (vs L3). I put it on a vlan, with an I-Sid. I've turned on snooping and proxy. It appears to be getting lost on the VSP somewhere. I think it's getting lost on the two VSP's that are VIST'd together.
Any special trick, or special commands that I can use to trace or troubleshoot?
Thanks in advance.
Mark
12-12-2022 07:02 AM
I don't have any ip vrrp defined in my network, so I'm assuming that I don't need to add those commands/parameters to the "interface vlan" section of my multicast vlan.
12-09-2022 06:52 AM
Thanks for this. I'll need to do some experimenting. I haven't set up any IP addressing on this vlan. I assumed since it was a L2 network, and I was just passing a (multicast) signal through, I didn't need IP addresses.
12-08-2022 05:50 AM - edited 12-08-2022 05:53 AM
When working with SPBm and Multicast with mixed network of VSPs and ERSs there are special considerations. The biggest is that ERSs can't see routed IGMP traffic when running in Fabric L2 mode. Unless they are in Fabric L3 mode running IPshortcuts. which requires the premier license.
are the ERS's L2 devices or are they enabled for SPBm? I assume because you are using an MLT to the ERS that its L2.
Are you doing any inter-vlan routing? Or is everything in the same VLAN?
Do you have ip spbm multicast enabled for the gobally and per vlan on the VSP?
Also, what tools are you using to test the multicast??
can recommend using MC Hammer. Its an old NORTEL tool that PELCO still makes available.
https://support.pelco.com/s/article/Using-Multicast-Hammer-1538586730634?language=en_US
12-09-2022 06:29 AM
Hi Paul,
The ERS's are L2, as you assumed.
No inter-vlan routing. Everything is on the same vlan
I have ip spbm multicast enabled globally. I tried to ip spb-multicast per vlan, but it won't let me, since I don't have an IP address on it.
I haven't used any tools, since I didn't know what tools might be available, either 3rd party or native to VSP/ERS.
12-10-2022 06:36 AM - edited 12-10-2022 06:43 AM
This will 100% work, I have made this work all three ways.
in your case.
If everything is in the same L2 VLAN domain everything should work as Multicast will get flooded throughout the entire VLAN.
If the ERSs are just in normal L2 mode (or SPBm mode) you need to make sure that in the VLAN you are using that "ip igmp snooping" is enabled.
As for tools.
use the MC Hammer tool I linked to the original reply. You just need to install it on two windows laptops.
