09-08-2020 07:29 PM
I am trying to create a regular expression that will filter just the section of the port given the last numbers of the serial number using the command sh lldp neighbor med inventory
I have the following output:
Port: 1/3 Index: 48 Time: 0 days, 00:02:32
ChassisId: Network address IPv4 x.x.x.x
PortId: MAC address 00:00:00:00:00:00
SysName: xxxxxxxxx
SysCap: TB / B (Supported/Enabled) HWRev: 9620D02L FWRev: hb96xxua3_1_02_S.bin
SWRev: ha96xxua3_1_02_S.bin SerialNumber: 10FA00001231
ManufName: Avaya ModelName: 9620
AssetID:
Port: 2/5 Index: 53 Time: 0 days, 00:02:32
SysName: x.x.x.x
SWRev: ha96xxua3_1_02_S.bin SerialNumber: 10FA00001234
AssetID:
Port: 3/40 Index: 54 Time: 0 days, 00:02:33
SysName: x.x.x.x
SWRev: ha96xxua3_1_02_S.bin SerialNumber: 10FA00001235
AssetID:
I would like to show the port for the serial number tat ends with 001234. So I would like the following output:
SysName: x.x.x.x
AssetID:
So far I have tried the following regex expression, but it doesn’t display anything:
sh lldp neighbor med inventory | find /Port.001234/
Solved! Go to Solution.
09-25-2020 08:59 AM
Roc156, Dilraj,
ERS is running on VxWorks with a limited support on regex expressions.
We cannot match the standard “\n” so the dirty solution I have is the following regex:
sh lldp neighbor med inventory | match "(Port: .+\/.+).+|SerialNumber: .+1234"
Regards
Mig
09-25-2020 03:28 PM
Oh wait! I think I cancelled it before giving it a chance. LOL.
I guess this dirty fix, will have to do.
Thanks again!
09-25-2020 03:14 PM
Roc156,
It will return the the first line for all the ports and the serial if it meet the REGX pattern 1234
Example:
Port: 4/46 Index: 676 Time: 230 days, 12:51:46
ChassisId: Network address IPv4 10.22.235.90
PortId: MAC address 00:08:5d:69:80:2f
SysName: Mitel IP Phone
SysCap: TB / TB (Supported/Enabled)
PortDesc: port 0
SysDescr: Mitel IP Phone
HWRev: 6865i FWRev: 5.1.0.5048
SWRev: 5.1.0.5048 SerialNumber: 00-08-5D-69-80-2F
ManufName: Mitel ModelName: 6865i
AssetID: 00-08-5D-69-80-2F
Port: 3/44 Index: 677 Time: 230 days, 22:50:03
ChassisId: MAC address 00:d8:61:48:5f:07
PortId: MAC address 00:d8:61:48:5f:07
Sys capability: O-Other; R-Repeater; B-Bridge; W-WLAN accesspoint; r-Router;
T-Telephone; D-DOCSIS cable device; S-Station only.
Total neighbors: 43
XXX#sh lldp neighbor med inventory | match "(Port: .+\/.+).+|SerialNumber: .+80-2F"
Port: 1/49 Index: 1 Time: 157 days, 01:09:35
Port: 3/49 Index: 3 Time: 157 days, 04:30:24
Port: 1/37 Index: 422 Time: 179 days, 11:41:19
Port: 3/27 Index: 444 Time: 187 days, 11:24:38
Port: 1/25 Index: 453 Time: 187 days, 11:28:02
Port: 3/25 Index: 459 Time: 187 days, 11:30:27
Port: 3/15 Index: 461 Time: 187 days, 11:30:54
Port: 3/21 Index: 462 Time: 187 days, 11:31:22
Port: 3/8 Index: 477 Time: 187 days, 11:39:16
Port: 2/13 Index: 481 Time: 187 days, 11:40:58
Port: 3/23 Index: 493 Time: 187 days, 11:45:28
Port: 1/13 Index: 505 Time: 187 days, 11:49:03
Port: 1/31 Index: 536 Time: 187 days, 11:56:00
Port: 2/38 Index: 538 Time: 187 days, 11:56:21
Port: 2/8 Index: 539 Time: 187 days, 11:56:38
Port: 3/32 Index: 542 Time: 187 days, 12:02:14
Port: 1/27 Index: 556 Time: 187 days, 12:06:58
Port: 3/19 Index: 558 Time: 187 days, 12:07:27
Port: 2/12 Index: 574 Time: 187 days, 12:18:38
Port: 2/10 Index: 576 Time: 187 days, 12:20:16
Port: 1/40 Index: 578 Time: 187 days, 12:36:42
Port: 1/38 Index: 581 Time: 187 days, 12:49:10
Port: 2/14 Index: 592 Time: 188 days, 08:14:41
Port: 3/3 Index: 594 Time: 190 days, 01:42:30
Port: 3/12 Index: 595 Time: 190 days, 02:33:44
Port: 3/48 Index: 652 Time: 221 days, 20:10:38
Port: 1/46 Index: 657 Time: 227 days, 01:32:28
Port: 1/45 Index: 658 Time: 227 days, 01:32:30
Port: 2/46 Index: 659 Time: 227 days, 01:32:39
Port: 1/47 Index: 660 Time: 227 days, 01:32:46
Port: 2/48 Index: 661 Time: 227 days, 01:32:48
Port: 2/26 Index: 662 Time: 227 days, 01:33:28
Port: 4/47 Index: 663 Time: 227 days, 01:33:58
Port: 4/48 Index: 664 Time: 227 days, 01:33:59
Port: 1/42 Index: 665 Time: 227 days, 01:34:02
Port: 1/48 Index: 666 Time: 227 days, 01:34:09
Port: 1/29 Index: 668 Time: 227 days, 01:43:20
Port: 1/35 Index: 672 Time: 227 days, 01:45:14
Port: 1/36 Index: 673 Time: 227 days, 01:45:36
Port: 1/34 Index: 674 Time: 227 days, 01:46:09
Port: 1/26 Index: 675 Time: 228 days, 09:34:00
XXX#
Up to you to adapt it
09-25-2020 03:10 PM
Thanks a bunch, though!
09-25-2020 08:59 AM
Roc156, Dilraj,
Regards
Mig
