05-07-2021 12:19 PM
Have a horrible feeling this is going to be an obvious one…. but can’t find any literature as to the reason why the static routes below keep going into a status of ‘INACTV’?
Only reference I found is that it might if the IP address isn’t reachable, which isn’t the case here?
In essence I am just trying to add a default route, and as you can see I’ve tried many iterations but all show inactive, and are pingable. None of the next hop addresses are directly connected.
I believe in VOSS the next hop doesn’t need to be directly connected?
Core:1#show ip route static
Command Execution Time: Fri May 07 12:11:27 2021 GMT
IP Static Route - GlobalRouter
DEST MASK NEXT NH-VRF COST PREF LCLNHOP STATUS ENABLE NAME
0.0.0.0 0.0.0.0 172.20.248.221 GlobalRouter 1 5 TRUE INACTV TRUE
0.0.0.0 0.0.0.0 172.20.250.210 GlobalRouter 1 1 TRUE INACTV TRUE
0.0.0.0 0.0.0.0 172.20.255.221 GlobalRouter 1 1 TRUE INACTV TRUE
10.119.192.0 255.255.255.0 172.20.255.221 GlobalRouter 1 1 TRUE INACTV TRUE
Total Static Routes Displayed: 4
Core:1#ping 172.20.248.221
Sending ping in context grt
172.20.248.221 is alive
Any idea what might be happening here?
Many thanks.
Solved! Go to Solution.
05-07-2021 03:32 PM
Martin,
The last trick (not reccomended but I don’t catch all your setup) would be to declare the next hop as non local changing the last flag in the screenshot here to false:
or via CLI with
no ip route 0.0.0.0 0.0.0.0 192.168.101.121 local-next-hop enable
Mig
05-07-2021 02:48 PM
Hi Mig,
See output below.
The only one I can’t get you is “show vlan mac-address-entry” as none of the address below in the routing table are associated to a VLAN they, are just CLIP address of all the other fabric routers.
If you was to hop on one of those other routers the routing table are very considerably larger because they contain all the OSPF routes.
You can see I’ve tried adding different static routes to different IP addresses listed below, which are reachable via ping?
I was wondering if the new management segmentation that come out in 8.2 (that these are running) has something to do with it, maybe something additional I need to add?
Is there a separate command to add a route in reference to the management CLIP, this is how I configured it. This is the address I am able to SSH to from the other fabric switches, just not the rest of the network because of that missing default route?
mgmt clip vrf GlobalRouter
ip address {{ mgmtClip }}/{{ mgmtClipMask }}
enable
exit
#show ip route
Command Execution Time: Fri May 07 14:33:15 2021 GMT
IP Route - GlobalRouter
NH INTER
DST MASK NEXT VRF/ISID COST FACE PROT AGE TYPE PRF
172.20.248.211 255.255.255.255 Cor-CEF-Core1 GlobalRouter 70 4051 ISIS 0 IBS 7
172.20.248.212 255.255.255.255 Cor-CEF-Core2 GlobalRouter 110 4051 ISIS 0 IBS 7
172.20.248.213 255.255.255.255 Cor-CEF-WAN01 GlobalRouter 80 4051 ISIS 0 IBS 7
172.20.248.221 255.255.255.255 Cor-2A22-Core1 GlobalRouter 10 4051 ISIS 0 IBS 7
172.20.248.222 255.255.255.255 Cor-2A22-Core2 GlobalRouter 60 4051 ISIS 0 IBS 7
172.20.248.223 255.255.255.255 172.20.248.223 - 1 0 LOC 0 DB 0
172.20.250.128 255.255.255.248 Cor-2A22-Core1 GlobalRouter 10 4051 ISIS 0 IBS 7
172.20.250.208 255.255.255.252 Cor-2A22-Core1 GlobalRouter 10 4051 ISIS 0 IBS 7
172.20.250.216 255.255.255.252 Cor-CEF-Core1 GlobalRouter 70 4051 ISIS 0 IBS 7
172.20.250.244 255.255.255.252 Col-2A22-Core2 GlobalRouter 60 4051 ISIS 0 IBS 7
172.20.250.248 255.255.255.252 172.20.250.250 - 1 4053 LOC 0 DB 0
172.20.255.211 255.255.255.255 Cor-CEF-Core1 GlobalRouter 70 4051 ISIS 0 IBS 7
172.20.255.212 255.255.255.255 Cor-CEF-Core2 GlobalRouter 110 4051 ISIS 0 IBS 7
172.20.255.213 255.255.255.255 Cor-CEF-WAN01 GlobalRouter 80 4051 ISIS 0 IBS 7
172.20.255.221 255.255.255.255 Cor-2A22-Core1 GlobalRouter 10 4051 ISIS 0 IBS 7
172.20.255.222 255.255.255.255 Cor-2A22-Core2 GlobalRouter 60 4051 ISIS 0 IBS 7
172.20.255.223 255.255.255.255 172.20.255.223 - 1 4090 LOC 0 DB 0
17 out of 17 Total Num of Route Entries, 17 Total Num of Dest Networks displayed.
#show ip route | in 172.20.248
Command Execution Time: Fri May 07 14:34:16 2021 GMT
Nonlocal next hop, how do I configure that or set the flag if that is an option I should try?
#ip route 0.0.0.0 0.0.0.0 10.10.10.10 ?
enable Enable the route.
local-next-hop Enable static route local-next-hop
name Set the static route name
preference Route preference
weight Create a route;cost of hops
Thanks
05-07-2021 02:12 PM
Dany,
I wouldn’t do that static arp entry.
You can flag the route as non-local-hop in the config with an argument in the command or via the GUI.
Mig
05-07-2021 01:50 PM
If it is a non-local-next-hop, you need to add a static ARP entry to make the route active:
192.168.100.0 255.255.255.0 172.18.143.254 GlobalRouter 1 1 TRUE INACTV TRUE
192.168.100.0 255.255.255.0 172.18.143.254 GlobalRouter 1 1 TRUE ACTIVE TRUE
From the VOSS guide:
A static route is a route to a destination IP address that you manually create.
The Layer 3 redundancy feature supports the creation of static routes to enhance network stability.
Use the local next hop option to configure a static route with or without local next hop.
You can configure static routes with a next hop that is not directly connected, but that hop must be
reachable. Otherwise, the static route is not enabled.
Layer 3 redundancy supports only address resolution protocol (ARP) and static route. Static ARP
must configure the nonlocal next-hop of static routes. No other dynamic routing protocols provide
nonlocal next-hop.
05-07-2021 01:12 PM
Martin,
Without global overview it is not so easy to debug.
Can you share the result of
- show ip interface
- show ip route | in 172.20.248.
- show vlan mac-address-entry XXX where XXX is the VLAN hpsting the subnet 172.20.248.
Mig
05-07-2021 12:35 PM
Hi Mig,
Here is the traceroute:
Core:1#traceroute 172.20.248.221
Sending traceroute in context grt
traceroute to 172.20.248.221, 30 hops max, 56 byte packets
1 172.20.248.221 1.291 ms 0.805 ms 0.759 ms
To add a little context here….. this VSP is connected to the network and natively sharing routes via ISIS, so it is aware of all other ISIS routes in the fabric.
The other routers though have both ISIS and OSPF enabled, and ISIS is being distributed into OSPF
This VSP is therefore only away of ISIS routes, but the Mgmt CIip is being advertised into the wider network and being learnt and shared by OSPF, so that direction is good.
I can’t reach the Mgmt Clip of this VSP via the wider network, only on local ISIS shared routes (all the other fabric switches) because I need to add a default route back into the network for the OSPF routes its not aware of.
I could redistribute OSPF into ISIS, or enable OSPF on this router, but it doesn’t need to know that level of detail, just point back to the primary routers that have the routing entries - that may break the concept of fabric, so interested on the response.
What has been perplexing me, this aside, is what address to use as the next-hop, seeing as it must be an ISIS learned IP.
Those static routes are pointing to MGMT and ISIS Clips of the other routers (as the ISIS learned IP’s), hence why they are reachable, but that could be part of the problem?
Appreciate you might need a little context here, so let me know if you need anymore detail.
Cheers,
Martin
