VSA for Avaya / Extreme ERS switches doing SPBM
jprins
In the documentations for Avaya Fabric Connect Avaya has documented what VSA's to use to configure a I-SID / VLAN mapping for a client authenticated using 802.1x, but they haven't added the VSA information dictionary data. Does anyone have this information?
I'm looking for the dictionary information for the following VSA's:
• Avaya-Fabric-Attach-VLAN-ISID
• Avaya-Auto-VLAN-Create
• Avaya-Fabric-Attach-VLAN-PVID
• Avaya-Fabric-Attach-Mode
• Avaya-Fabric-Attach-Client-Type
• Avaya-Fabric-Attach-Client-Id
Thank you very much.
Jan Hugo Prins
7 REPLIES 7
akrohn
I can’t upload the Excel File.
akrohn
Now i have it.
# -*- text -*-
# Copyright (C) 2015 The FreeRADIUS Server project and contributors
#    Nortel Passport 8600 VSA's.
#    http://www142.nortelnetworks.com/bvdoc/setips/july04/engineeringtipstricksv12.pdf
#    $Id: 2eca7cd9b7bb44fef3b4c563307edc2f2bf26928 $
VENDOR        Nortel                562
BEGIN-VENDOR    Nortel
ATTRIBUTE    Nortel-User-Role            110    string
ATTRIBUTE    Nortel-Privilege-Level            166    integer
ATTRIBUTE    FA-VLAN-Create                170    integer
ATTRIBUTE    FA-VLAN-ISID                171    string
ATTRIBUTE    FA-VLAN-PVID                172    integer
ATTRIBUTE    FA-Switch-Mode                180    integer
ATTRIBUTE    FA-Client-Id                181    string
ATTRIBUTE    FA-Client-Type                182    string
ATTRIBUTE    FA-Client-PSK                183    integer
ATTRIBUTE    FA-Client-Trust                184    integer
ATTRIBUTE    FA-Client-Trusted-Binding        185    string
ATTRIBUTE    FA-Service-Request            186    string
ATTRIBUTE    Passport-Command-Scope            200    integer
ATTRIBUTE    Passport-Command-Impact            201    integer
ATTRIBUTE    Passport-Customer-Identifier        202    integer
ATTRIBUTE    Passport-Allowed-Access            203    integer
ATTRIBUTE    Passport-AllowedOut-Access        204    integer
ATTRIBUTE    Passport-Login-Directory        205    string
ATTRIBUTE    Passport-Timeout-Protocol        206    integer
ATTRIBUTE    Passport-Role                207    string
VALUE    FA-VLAN-Create        FA-VLAN-Create-Disabled        0
VALUE    FA-VLAN-Create        FA-VLAN-Create-Enabled        1
VALUE    FA-Client-Trust        FA-Switch-Trust-None        0
VALUE    FA-Client-Trust        FA-Switch-Trust-All        1
VALUE    FA-Client-Trust        FA-Switch-Trust-Restricted    2
VALUE    Nortel-Privilege-Level        VoiceMailAdmin        0
VALUE    Nortel-Privilege-Level        ContactCenter        1
VALUE    Nortel-Privilege-Level        SBAInstaller        2
VALUE    Nortel-Privilege-Level        SBASystemCoord        3
VALUE    Nortel-Privilege-Level        SBASystemCoordBasic    4
VALUE    Nortel-Privilege-Level        SBABasic        5
VALUE    Nortel-Privilege-Level        Security        6
VALUE    Nortel-Privilege-Level        CTEApp            7
VALUE    Nortel-Privilege-Level        SBA-IPSetRegistration    8
VALUE    Nortel-Privilege-Level        Application-BCMMonitor    9
VALUE    Nortel-Privilege-Level        CDRApp            10
VALUE    Nortel-Privilege-Level        ModemLogin        11
VALUE    Nortel-Privilege-Level        GuestLogin        12
VALUE    Nortel-Privilege-Level        AdminDownload        13
VALUE    Nortel-Privilege-Level        ExclusiveAccess        14
VALUE    Nortel-Privilege-Level        Admin            15
VALUE    Nortel-Privilege-Level        DataAdmin        16
VALUE    Nortel-Privilege-Level        RemoteAccess        17
VALUE    Nortel-Privilege-Level        Guest            18
VALUE    Nortel-Privilege-Level        VoiceAdmin        19
VALUE    Nortel-Privilege-Level        BackupOperator        20
VALUE    Nortel-Privilege-Level        RemoteMonitoring    21
VALUE    Nortel-Privilege-Level        SoftwareUpgrade        22
VALUE    Nortel-Privilege-Level        AlarmViewer        24
VALUE    Nortel-Privilege-Level        OperationalLogs        26
VALUE    Nortel-Privilege-Level        DiagnosticLogs        27
VALUE    Nortel-Privilege-Level        ApplicationIVR        28
VALUE    Nortel-Privilege-Level        ISDN-Dial-in        30
VALUE    Nortel-Privilege-Level        WAN-Dial-in        32
VALUE    Nortel-Privilege-Level        System-SerialPort    36
END-VENDOR    Nortel
jprins_at_bette
That blue table was the one I was looking for, and in my case I needed it for the ERS5900 series. The complete set is now available in the dictionary.nortel in FreeRadius.
akrohn
