AP2600 problem with Android 11
uwcd
Users with android 11 cannot connect to our wifi network. We are using AP2600 Platform.
NAC version is 6.3.0.186
Controller is V2110 Medium, system version is 09.21.20.0001
Is there any option in extreme?
I tried to generate and upload a certificate but it didn’t help.
14 REPLIES 14
StephanH
Valued Contributor III
Assuming you are using 802.1x with PEAP. Have you also installed all intermediate certificates? So the whole chain?
Regards Stephan
Miguel-Angel_RO
Please double check this: https://extremeportal.force.com/ExtrArticleDetail?an=000092023
and ensure the domain entered is matching the domain of the certificate
uwcd
Dear Miguel,
Thank you for your reply. Yes we have the same issue. I tried to install the certificate on the Android 11 phone, selected the certificate on the connection settings page but cannot connect to the WiFi. Yes, we are using PEAP. It is working with pre-shared key, but we need to use user authentication method, as we have different VLANs with different access rights for different users (students, teachers, staff)
StephanH
Hello uwcd,
which method do you use for authentication in the WLAN? EAP-TLS, PEAP? If yes, have you already used pre-shared keys to narrow down the error?
Regards Stephan
Miguel-Angel_RO
