AP305c Power status low
Pedro_Rocha
New Contributor III
Hi team,
I have installed a wifi network on a warehouse with AP305C. But the customer wanted to use Aruba switches and now I have all the APs with the low power status.
Can you explain what are the consequences of this issue?
Thanks!
1 ACCEPTED SOLUTION
Jan_Reister
Contributor
Check out low-power mode for AP305C. Usually it means that POE is 802.3af (and not POE+ 802.3at), the AP may use half the radio chains or even crash repeatedly.
2 REPLIES 2
Pedro_Rocha
New Contributor III
Thank you very much @Jan_Reister.
I need to explain to the customer the importance of providing the correct power to the APs.
Jan_Reister
Contributor
