AP3605/AP3610 indicator lights - what do they mean?
Geoff_Smith
I am putting together a Knowledgebase article for our service desk staff and am wondering if there is a guide anywhere as to what the different light combinations on a AP3605/AP3610 wireless access point indicate.
9 REPLIES 9
Geoff_Smith
Thanks Branden for the useful info regarding the Blue/Green status. Also - the capability to identify an AP by making the lights flash could be useful. I have noticed that during bootup some of the indicators flash Red as well. I assume this indicates firmware download, etc. In one instance an AP would not function and one of the indicators was flashing Red. Eventually I resolved the problem by having the cabling to the AP re-done. Understanding what the Red light indicated may have helped resolve this issue quicker so if Tamera is able to dig up a complete list of status indications it would be appreciated.
Branden_Henner1
First light is typically always green. It indicates power status. Second light indicates copper link speed. Green = 100MB and Blue = 1GB. The other two lights are radio 1 and 2. Green = A/B/G and Blue = N. Edit: I forgot to mention, this is called normal operation. You can also set the LED lights to display identify operation or turn them off completely. Identify operation is quick repeated flashing in order to locate the AP you're looking for. this can be changed by selecting the particular AP under the wireless APs tab of the controller then clicking the Advanced button.
I'm referring to the link speed that both the switch port and cable in between is capable of.
I am probably over-thinking this. When you say "copper link speed"; do you mean the cable from the AP to the data drop, or from the data drop to the patch panel to the switch?
Tamera_Rousseau
Hi Geoff, I am doing a little research and will have something posted shortly...Thanks!
