AP3605/AP3610 indicator lights - what do they mean?
‎10-17-2013 01:57 AM
I am putting together a Knowledgebase article for our service desk staff and am wondering if there is a guide anywhere as to what the different light combinations on a AP3605/AP3610 wireless access point indicate.
9 REPLIES 9
‎10-21-2013 04:56 PM
Thanks for posting the link to the users guide James! I am going to add this guide to our FAQ for others that may have this same question. Thanks again!
‎10-19-2013 09:27 PM
Thanks James. This is exactly what I need. I had looked in the AP36xx documentation and was not able to find the info. Did not think to look in the wireless convergence software guide.
‎10-18-2013 06:21 AM
This was very handy for me, thanks for posting!
‎10-17-2013 08:40 PM
It is normal to see the AP flashing red during boot. If the access point can not contact a controller for some reason it will continually reboot itself. Sometimes this can be due to a bad ROP or a misconfiguration. I recommend taking it on a case by case basis unless you're referring to a widespread issue. However, I will say that you should not see the AP flashing red during a firmware update process. It will typically alternate green flashing.
