It is normal to see the AP flashing red during boot. If the access point can not contact a controller for some reason it will continually reboot itself. Sometimes this can be due to a bad ROP or a misconfiguration. I recommend taking it on a case by case basis unless you're referring to a widespread issue. However, I will say that you should not see the AP flashing red during a firmware update process. It will typically alternate green flashing.
