Draeger medical device
Azienda_Sant_An
New Contributor II
Hi
we work in an Italian hospital. We need to connect some medical device, Draeger Infinity M300 telemetry transmitters, to our wireless Infrastructure.
What is the correct configuration that I need to consider ?
We have a V2110 Wireless Controller and many 3705i AP model.
Do you have any guide?
Thanks
Fabrizio Stoppani
12 REPLIES 12
Nico_Willamowsk
New Contributor III
At first you write M300 and now M330! What do you mean? The M300 is a medical monitor.
Azienda_Sant_An
New Contributor II
Really if I read the Infinity M330 datasheet , it speak about a Non-Multicast VLAN. I think that multicast works for another kind of device, for example medical monitors.
Nico_Willamowsk
New Contributor III
At first, you had to enable "Multicast Support" on ESA0. It“s only possible to enable it on ESA0. Mulicast Assembly at the AP must be enabled (AP Proberties->Advanced->IP Multcast Assembly). You must have the actual firmware, problem with MTU Size is fixed in v8.32.05.007. But in Version 9 the problem still exists, but now it“s fixed in version 9.12.02.0006. You have the fix the channel at the M300 and also at the AP!
