Extreme Control behind a firewall
Anonymous
Not applicable
Currently looking into running a NAC behind a firewall and looking into this GTAC post:
https://extremeportal.force.com/ExtrArticleDetail?an=000083367
Which says the following:
Populate /appdata/nat_config.txt in NetSight Server with NAT mapping of NAC(s)
But the nat_config.txt file is blank, so I have no reference as to what I should enter into that file that constitutes a ā€˜NAT mappingā€™, so just wondered if anyone within the community might know.
Many thanks in advance.
3 REPLIES 3
Anonymous
Not applicable
Hi Kawawa,
Odd, yeah, the file was completely blank 0KB.
I've since edited it now, so it has the single entry in it, was running a fresh OVA installation of XMC version 8.1.3.65
Thanks for the info anyway.
Will post back if it works.
Cheers
Kawawa
How were you checking the content of the nat_config.txt file? I'm not sure it should be blank:
captain@spock.vulcan.local:~$ cat /usr/local/Extreme_Networks/NetSight/appdata/nat_config.txt
# The nat_config.txt file is used to configure NetSight to work in a NAT
# environment. The file maps local IP addresses to their remote IP address.
# A local IP is defined as an IP addresses of system on the same side of
# the NAT firewall as this server and a remote IP address is defined as the
# corresponding IP address of that end system on the other side of the NAT
# firewall.
# The format for each line should be: =
# EX:
# 10.20.80.155=134.141.90.221 # Some note or description.
# 10.20.80.156=134.141.90.222 # Some note or description.
Anonymous
Not applicable
Think I've found the answer:
Will post back if I get it working
