Extreme Management Center 8.1.1.41 Open Device Terminal with Radius
Tiburcio_Jr_Cor
New Contributor II
Is it possible to login to Device Terminal using Radius login in EMC 8.1.1.41? In Ridgeline you were able to telnet into switches using Radius. If not can this be added to the next release?
1 REPLY 1
Ryan_Yacobucci
Hello,
We currently have two open feature requests for the Device Terminal feature in Extreme Management Center:
01513326 is for better logging of the "Open Terminal Session" feature
01394666 is to not use the pre-defined password, but have the user input the password. This will work when the switch has RADIUS management login enabled.
It's not clear when they will be added to the product, but we are working on it.
Thanks
-Ryan
