Extreme NAC and Cisco WLAN controller integration for Guest Self Registration and Sponsor approval
Ullas_Udayakuma
Is it possible to integrate Cisco WLAN controller with Extreme NAC to enable guest self registration and sponsor authentication feature for WLAN Guest network.
2 REPLIES 2
kasibatlasai07
Hi Ullas
Did you find the solution for this? Can you help me with any reference document please.
Regards
KVKSAI
Zdeněk_Pala
It is easier and more feature rich if it is done with Extreme Wireless solution. You will have all statistics and many cool features with our wireless. But yes it is possible to integrate Cisco wireless with our Extreme IAC (nac solution). I do not have any information about Cisco-Meraki wireless integration with our IAC. Zdenek
Regards Zdeněk Pala
