Wireless planner undergoing maintenance for a couple of weeks
Sjoerdg
New Contributor III
Dear Community,
I am wondering why the Extreme Wirelessplanner (wirelessplanner.extremenetworks.com) has been under maintenance for a couple of weeks now.
I would like to use the tool, but because of the maintenance I am unable to login.
Does somebody know when the tool is out of maintenance?
Thank you,
Sjoerd
3 REPLIES 3
Sjoerdg
New Contributor III
Thank you both for the reply on this topic.
I can now indeed see that the wireless planner is working again. The maintenance banner is also gone.
Why it was in maintenance for a while is still unclear........
The most important is that it is working again.
Regards,
Sjoerd
DanieSuad
As far as I know, this site is still up and running. This tool has not been retired. I just checked it. It is easy to plan, configure and deploy a wireless LAN. Very easy to generate PDF reports with access point locations. I even planned to automate end-to-end network operations for my office. The date is april 2023 calendar. I decided to do this to protect and optimize the user and application experience. I hope you will get help on this forum and that my post was helpful to you. In any case, I wish you a good day.
pontaclode
Friend, this site is still working. I just checked it.
