04-12-2024 08:58 AM
It appears that back in 2018 before Aerohive acquisition by Extreme Networks, it was at least tolerable for the equipment to be used in home networks (see legacy post @maxtaylor106 ). Why is this no longer the case? (I'd like to use an AP310i in router mode, but...)
Thanks
Solved! Go to Solution.
04-13-2024 10:58 AM - edited 04-15-2024 05:20 AM
the 310i is not a cloud enabled AP. TTBOMK it will only run in Controller mode or Wing mode.
see bottom left hand corner of the factsheets.
Monday
In commercial office facilities, retail venues, and enterprise buildings, low-voltage networking and wireless AP deployments depend heavily on proper physical site conditions. When planning network rollouts in new commercial buildings or retrofitted office suites, IT teams routinely coordinate with facility managers to verify dedicated server room cooling, PoE switch power capacity, and cable plenum pathways. For teams assessing a new commercial space and reviewing physical building readiness, baseline due diligence resources like https://inspecwise.com/commercial-inspection-checklist/ provide a great framework for evaluating server room electrical feeds, HVAC climate controls, and life-safety standards before deploying enterprise network hardware.
04-14-2024 03:39 AM
Thanks. I did see the datasheet, but thought web UI configuration was also possible, which didn't work for my unit using the "zero-config IP." But AP reference guide for WiNG 7.9.4.0 states AP310 is included, and p41 recommends using Router Mode for single-AP deployment. So that implied it might work. (I can use in either mode, but just AP adds an edge router.)
The crux:
I wanted more capable hardware that was less subject to CVE and other problems of typical SOHO units. 🤔
