Extreme Wireless C35 and MAC Authentication using Server 2016 Network Policy Server
robertmare
I have exhausted all documentation and suggestions for configuring Microsoft RADIUS to MAC Authenticate to our Private SSID.  We are using C35 controllers and Server 2016, has anyone been able to get this to work?  If so, what instructions/guides were followed?
I appreciate any suggestions or recommendations!
Thank you.
1 ACCEPTED SOLUTION
Brian_Anderson1
Contributor II
If your ssid is set to bridge at ap and you aren’t using AP-Aware, then the port being set to .1x may affect your authentication.
However, if your ssid is set to 802.1x and your domain computer has 802.1x turned on, then this protocol will take precedence and will try to authenticate with the username and password of either the computer or user, depending on how the computer is configured and where in the login process the computer is in.
I’d start with unchecking the requirement on the client to check for certificate and go from troubleshooting from there.
8 REPLIES 8
robertmare
I will try.  Thank you for the reply!
Brian_Anderson1
Contributor II
robertmare
It is in fact a domain computer.  I apologize, however haven’t used NPS/RADIUS in quite sometime so unsure as to what you mean by using .1x?  The port for the connection policy is Wireless 802.11x….but doubt thats what is meant here?
Brian_Anderson1
Contributor II
What kind of device are you trying to authenticate? If a domain computer, why not use .1x?
