ios 7.1.1&7.1.2 any know problems regarding WLAN connection
Ronald_Dvorak
Honored Contributor
Anyone got reports from the customer site that they run into issues with ios 7.1.1/7.1.2
My customer called me and reported that some IPhones/IPads are not able to connect to the 802.1X PEAP SSID (EWC 08.32.05.0007).
Initial remote troubleshooting show that the client is connected to the SSID and also the correct NAC roles hit but the IPad didn't get an IP.
I've tried some things but only after we've rebooted the IPad is was working.
I've read about some connection issues ... https://discussions.apple.com/thread/6430543 but I'm not sure whether that are only a handfull of worldwide users or whether there is a general issue with the device.
Just want to find out whether someone else has the same kind of issue before I'll go onsite next week.
Thx,
Ron
1 REPLY 1
Werner_Rappl
Hi Ron,
it seems we have the same issue with other clients.
Please trace the air and the AP-Tunnel - in my case discard the AP the arp packets.
After the reboot from the client is the session running.
We have for our problem an open case šŸ™‚
BR Werner
