netlogin mac authentication issue
‎03-14-2016 03:18 PM
Correct me if i am wrong:
In NetLogin by mac address, the user and password sent by the Summit to the NPS are capitalized(uppercase) . As the case sensitice password, how can I make the switch to send the password in lowercase?
Best Regards
VB
Best Regards
VB
5 REPLIES 5
‎06-29-2017 03:03 AM
same problem at my current project - several thousands mac addresses are part of global NPS in lower case because this is HP switching default. EXOS now only support upper case ...
HP / Brocade / Cisco support to define the format of mac authentication (upper / lower case ....)
This is a overdue feature!
Is there maybe a way to transform the mac format if it goes through Extreme NAC Gatway ?
Is there maybe a way in NPS to ignore password checking (because i think, only password checking in NPS is case sensitive, not username) ?
Regards
Regards
‎03-18-2016 05:47 AM
Hi Vitor,
Unfortunately it is not possible via script.
‎03-18-2016 04:25 AM
Hi Vitor,
I believe you can chance the password to upper case in Active Directly, i would say that is an easy option.
since the packet is generated by the CPU I am not sure if a script can do it, i would say it has to be a change in the code...Still i would check with the team if this is possible via a script.
‎03-16-2016 03:39 AM
Hi Vitor,
Current implementation does not have an option to change the case of "user-password" attribute to lower case so this case be further submitted as a feature request to check if this can be implemented in the future
