SSH users with RADIUS authentication not getting administrator privileges
Jairo_Rojas_Her
New Contributor II
Thanks Patrick
I have problems with SSH2 authentication on summitX-in version 16.1.3.6 16.1.3.6 1-2.cos-patch-patch 1.2. When authenticates about Radius with a user who has administrator permissions not let modify read-only changes. Version may have problem?
This the more information about firmware last intalled
# sh ver images
Card Partition Installation Date Version Name Branch
Switch primary Fri Nov 7 18:35:13 UTC 2014 15.5.3.4 summitX450-15.5.3.4.xos v1553b4
Switch secondary Thu Apr 14 10:13:01 COT 2016 16.1.3.6 summitX-16.1.3.6-patch1-2.xos 16.1.3.6-patch1-2
Switch secondary Thu Apr 14 10:15:20 COT 2016 16.1.3.6 summitX-16.1.3.6-patch1-2-ssh.xmod 16.1.3.6-patch1-2
Note: This conversation was created from a reply on: NO MESSAGE DECODE; Missing component "AAA.RADIUS" v38.1.
14 REPLIES 14
Jairo_Rojas_Her
New Contributor II
This equipment is new and installation is new. Quizimos try this new firmware and only works Telnet.
The problem is with the version 16.1.3.6 Patch 1-2 when required to manage the switch by SSH2 not allowed to enter as administrator only shows reading options.
Hi Jairo,
Is the same user that is having trouble in 15.6 able to work in 15.3?
Is the SSH module downloaded and installed on the switches with 15.6?
Has SSH2 been enabled in the switches with 15.6?
Can you post a 'show management' from the switch?
Jairo_Rojas_Her
New Contributor II
We have the same configuration of Radius 800 switches more but with version 15.3.3.5 v1533b5-patch1-6
Patrick_Voss
Hello Jairo,
Did the Radius setup ever work properly or is this a new setup?
