Wireless Radius disconnect
Andre_Brits_Kan
Contributor II
Hi Does the Enterasys Wireless controller (V2110) support the Radius disconnect attributes? Disconnect-Request (40) Disconnect-ACK (41) Disconnect-NAK (42) I have a scenario where clients connect and authenticate via a Radius server. The radius accounting monitors the amount of data used, once the user have reach a specific limit I would like to disconnect the user using radius disconnect messages. Thx
9 REPLIES 9
Doug
Have you been able to make any progress on this? I would try including the session-timeout in the return attributes that get included in the RADIUS accept.
-Doug
Doug Hyde
Sr. Director, Technical Support / Extreme Networks
Doug
Session-Timeout should work. Can you get a trace of the RADIUS accept packet?
-Doug
Doug Hyde
gherbiet
New Contributor II
Hi all,
I have approximately the same question as Andre : I would like to disconnect a 802.1X (EAP-PEAP) authenticated wireless user when the corresponding session expires.
I use FreeRADIUS with the "Expiration" attribute for the user, that properly generates a "Session-Timeout" reply-attribute that is sent back to NAS. However, it doesn't seem to be properly interpreted as the user is not disconnected when the session expires.
I don't use NAC so EWC directly interacts with FreeRADIUS. Is the "Session-Timeout" interpreted by the EWC (so I am missing something in my config) or is the only solution to rely on RFC3576 (which FreeRADIUS is doing from what I have read, although I never tempered with it myself)?
Thanks in advance for your reply.
Regards.
Jon_Linton
New Contributor II
I do not see the disconnect attributes on the release notes. The release notes show all the supported RADIUS attributes.
Tamera_Rousseau
Andre, did you need additional information regarding configuring this? If so, let me know and I can point you in the right direction. Thanks!
