Access points
Access points
JeremyClarkson
Does Extreme not provide Access Points that dont need a controller?
7 REPLIES 7
Correct - Today, the AP3935i can be managed by ExtremeCloud. That said, it is important to keep in mind that the same AP can be managed by ExtremeCloud or On-Premise. In other words, if your business imperatives drive you to transform from Cloud-Managed to Local-Controller-Managed, you can continue to operate using the same Access Points.
AFAIK only 39xx because there is a special certificate factory pre-laoded for authentication to the CLOUD controller.
JeremyClarkson
dont matter i just found the answer?
https://community.extremenetworks.com/extreme/topics/clarification_semi_autonomous
I am dissapointed.
