airprint randomly stops working
Joe_Kozura
New Contributor II
this is a new identifi install with 4x4 APs
the legacy Meru install was working flawlessly
the airprint server disappears after an amount of time, turning the airprint server's wifi off then back on gets functionality back
multicast settings are set to allow all multicast traffic
not sure what to adjust to get airprint to continuously work
thanks!
I love this community!
15 REPLIES 15
Ronald_Dvorak
Honored Contributor
You should tell us a little bit more about the installation....
controller type, AP model, software version, setup of the WLAN service, topology used.
In case the used topology isn't bridge@AP could you give it a try with it to see whether you run into the same issue with this topology mode.
