AP3805i connect only at 100 Mb at X440G2-48p-10G4 switch
JohanHendrikx
Contributor II
I have more than 50 AP 3805i connected at X440G2-24p-10G4 and X440G2-48p-10G4 switches.
One AP connect with 100 mb instead of 1Gb.
Port settting on the switch is auto. Also at the AP.
I noticed that the interface setting on the AP is 10 or 100 Mb and not 1Gb??.
I already cleared the config of the AP but it stays 100 Mb
Other APā€™s connect with 1Gb.
Johan Hendrik System Architect Audax
13 REPLIES 13
Aman
New Contributor II
on switch you can configure the Speed for that particular port.
"configure port auto off speed < speed > duplex "
like this.
The link speed will be 10 Mb of 100 Mb. I cann't select 1Gb
Aman
New Contributor II
one thing you can also try just manually configure the link speed for that APs.
Aman
New Contributor II
do you have any WLC?
Zdeněk_Pala
If you move that AP to different port, will that change? If you swap AP with other AP in the same port. Will that change?
Regards Zdeněk Pala
