AP3915i low power mode error
Ronald_Dvorak
Honored Contributor
Why does the AP report low power mode ?
As per release notes the AP requires 802.3af and that is what my D2 is providing to the port.
Software installed = v10.41.05
BR,
Ron
9b1974dec5dd489980de785eee800d28_RackMultipart20180321-11292-a6habj-AP3915_lowpower_inline.png
13 REPLIES 13
Ronald_Dvorak
Honored Contributor
The problem is fixed with V10.41.07 which is no online in the download area.
Thanks team !!!
No problem Ron.
Doug Hyde
Director, Technical Support / Extreme Networks
Ronald_Dvorak
Honored Contributor
Back to business...
the datasheet for AP3915i/e doesn't mention that the 3915e needs 802.3at but in the KT slides 802.3at is listed as required for e-model.
What is correct ?
Thanks but why has the AP7632 (same hardware AFAIK) 802.3af & 802.3at in the datasheet.
Or does this AP support USB in the current sw and that is the reason.
If so it should be more clear that 802.3at is needed in case the USB is used IMHO.
cadc033866384dab85c1ab3dff0c9b41_RackMultipart20180322-59444-5w6060-AP7632_power_inline.png
