Backup wireless controller fail somtimes for some SSID
Husam
New Contributor II
Hi all,
I have setup of 2 wireless controllers, 5 SSID and 200 APs. 4 Topologies are bridged at EWC and one at AP. Everything is going and working well as all access points are active in the main wireless controller. But when some APs move to be active on the backup controller some SSIDs (bridged at EWC) don't work well sometimes for some users while other SSIDs keep working well.
I checked the path between two wireless controllers and all Topologies are reachable and synchronized.
I am using C5210 and software 09.21.06.0006 for both controllers
Anyone have an idea what could be wrong?!
Thanks in advance,
Husam
12 REPLIES 12
Husam
New Contributor II
for time as well they are going at same min!
Husam
New Contributor II
It is same topology and same configuration as I made and synchronized it from man controller.
The problem come up when some APs moved to be active on the backup controller and that result in some users can connect to wireless network but they can not have access to to any resources in the network even the default getaway, but some other users keep working normally.
regards,
Husam
Doug
Also make sure the time between controllers is synced (even if you have NTP configured)
Doug Hyde
Sr. Director, Technical Support / Extreme Networks
