Clients having connection issues using AP3805i with Hyper V V2110 version 10.21.2.0..
khaled_Abdulrah
kindly advice
4 REPLIES 4
Nathiya_M
Hi Khaled,
What type of authentication being used? Is it an issue with all the clients or specific?
Regards,
Nathiya M
Scott_Whall
Khaled - without any AP trace logs or controller logs, it will be hard to determine the root cause here. If you can provide those two items, and a description of the network environment, you can open a Case with our Support Desk.
Also - I would recommend going to 10.21.04, which is available on our Support Download site.
Andre_Brits_Kan
Contributor II
Can you provide more detail on the connection issues??
