Downgrading 5200 wireless controller from delivered code 10.11.03.004 to site code 09.21.11.0004
Rod_Robertson2
Contributor
My cleints have attempted to down grade a 5200 unit to verion 09.21.11.004 from the supplied version of 10.11.03.0004 ( this is so it matches the current operational box )
The downgrade has failed with the following prompt:
Error! Upgrade is not supported from major release :10
I would like to know how can I can downgrade the unit to the required software level
6 REPLIES 6
Sorry I cannot access the https link , do you have another as this keeps directing me to my internal 365 account.
Ronald_Dvorak
Honored Contributor
Downgrade isn't supported instead you load a rescue image with another/older firmware.
If you don't have a 9.21 resuce image from another C5210 you should contact the GTAC.
