EWC clonning WLAN, Role etc configurations.
Rahman_Duran1
New Contributor III
I need to create more than 10 auth and non auth roles and about 6 more WLAN services. They will be exacly same with one of the existing role and WLAN. I only need to change the topology settings (for different vlans). Unfortunately there is no option for clonning existing configs.
So can I dump the configurations via CLI then copy-edit-paste them for creating the needed roles and WLAN services? If it is possible can you share some code as I never used EWC CLI?
Thanks,
Rahman
9 REPLIES 9
Rahman_Duran1
New Contributor III
Unfortunately this does not work. I can create role via CLI but can not assign topology just after creating it. "Error: unrecognized command "topology-name"."
this is what I paste to CLI
role
create "acu-sehir-unauth"
"acu-sehir-unauth"
topology-name "B@EWC(vlan62)"
filter-status enable
ulfilterap enable
apcustom disable
name "acu-sehir-unauth"
default-cos no-change
access-control contain2vlan
traffic-mirror none
acfilters
create 1 proto any eth 800 mac any interface-ip in dst out src allow priority none tos-dscp none cos none traffic-mirror none
create 2 proto udp eth 800 mac any 0.0.0.0/0 port 68 in dst out src allow priority none tos-dscp none cos none traffic-mirror none
create 3 proto udp eth 800 mac any 0.0.0.0/0 port 53 in dst out src allow priority none tos-dscp none cos none traffic-mirror none
create 4 proto udp eth 800 mac any 0.0.0.0/0 port 67 in dst out src allow priority none tos-dscp none cos none traffic-mirror none
Any idea why it does not work?
Thanks,
Rahman
Gareth_Mitchell
You can also use Policy manager in ExtremeControl to copy and paste roles/rules/services.
Rahman_Duran1
New Contributor III
Hello Roy,
Thank you for the example. I will try it. I will also create a feature request about clonning btw.
Regards,
Rahman
Roy_Noh
Here is an example for you.
EWC.lab.extremenetworks.com# role
create "Test"
EWC.lab.extremenetworks.com:role# create "Test"
EWC.lab.extremenetworks.com:role# "Test"
EWC.lab.extremenetworks.com:role:Test# filter-status enable
EWC.lab.extremenetworks.com:role:Test# ulfilterap enable
EWC.lab.extremenetworks.com:role:Test# apcustom disable
EWC.lab.extremenetworks.com:role:Test# name "Test"
EWC.lab.extremenetworks.com:role:Test# default-cos no-change
EWC.lab.extremenetworks.com:role:Test# access-control allow
EWC.lab.extremenetworks.com:role:Test# traffic-mirror enable
EWC.lab.extremenetworks.com:role:Test# acfilters
EWC.lab.extremenetworks.com:role:Test:acfilters#
apply delete help set-filter-topology
config end logout set-snmpruletype
create exit move show
EWC.lab.extremenetworks.com:role:Test:acfilters# exit
EWC.lab.extremenetworks.com:role:Test# exit
EWC.lab.extremenetworks.com:role# create "Test1"
"Test1"
EWC.lab.extremenetworks.com:role# "Test1"
EWC.lab.extremenetworks.com:role:Test1# filter-status enable
EWC.lab.extremenetworks.com:role:Test1# ulfilterap enable
EWC.lab.extremenetworks.com:role:Test1# apcustom disable
EWC.lab.extremenetworks.com:role:Test1# name "Test1"
EWC.lab.extremenetworks.com:role:Test1# default-cos no-change
EWC.lab.extremenetworks.com:role:Test1# access-control allow
EWC.lab.extremenetworks.com:role:Test1# traffic-mirror enable
EWC.lab.extremenetworks.com:role:Test1# acfilters
EWC.lab.extremenetworks.com:role:Test1:acfilters# exit
EWC.lab.extremenetworks.com:role:Test1# exit
EWC.lab.extremenetworks.com:role# show
Role name Topology Class of Service Mode Filter defined
Lab Demo no-change no-change no-change Yes
Unregistered no-change no-change no-change Yes
Enterprise User no-change no-change no-change Yes
Guest no-change no-change no-change Yes
Lab Demo Turbo no-change no-change no-change Yes
GLB_ROLES no-change no-change no-change Yes
Failsafe no-change no-change no-change Yes
Administrator no-change no-change no-change Yes
Deny Access no-change no-change no-change Yes
Guest Access no-change no-change no-change Yes
Quarantine no-change no-change no-change Yes
Notification no-change no-change no-change Yes
Assessing no-change no-change no-change Yes
Test no-change no-change no-change Yes
Test1 no-change no-change no-change Yes
Please notice - Type in "exit" to go back to upper level.
Thanks
Roy_Noh
Hello Rahman,
It it's possible to copy, edit and paste by CLI commands.
You can check current configuration of EWC by "show run-config"
Below is a role part of the result for the command.
role
create "Guest" snmpid 4 1
"Guest"
ulfilterap enable
apcustom disable
name "Guest"
acfilters
You can edit it as your own purpose and paste it to the CLI prompt.
Please read carefully the link below since misconfiguration could affect your network seriously.
http://documentation.extremenetworks.com/wireless/CLI/downloads/Wireless_CLI_Reference_Guide.pdf
Thank you
