how to add vlan in extreme identi-fi wireless controller
ompal_singh
New Contributor II
how to add vlan in extreme  identi-fi wireless controller please share any document please do needful.
1 REPLY 1
Tomasz
Valued Contributor II
Hi Ompal,
In Extreme Wireless (ex. IdentiFi) VLAN = Topology (GUI: VNS > Topology). You can just decide additionally where should the wireless traffic be put to the wired network (at AP or at controller). Then you can use that topology for a WLAN (GUI: VNS > WLAN Service, Default Topology) or per user role (GUI: VNS > Roles, Action: Contain to VLAN).
Hope that helps,
Tomasz
