How to determine if AP is operating in 4x4:4
Dennis
New Contributor II
- 3935i-ROW on FW 10.41.06.0013
- patched to HP J9148A 2910al-48G-PoE+ Switch
AP Inventory report shows LAN1 using AF and not AT. Switch is capable of delivering 33W on a port. I'm still investigating but it appears disabling LLDP PoE negotiation on the HP switch via command:
no lldp config dot3TlvEnable poe_config... resolves the issue and AP Inventory report shows LAN1 using AT.
I just want to be certain that after doing this the AP is indeed operating in 4x4:4 MU-MIMO. Is there a way to tell, perhaps via logs on the AP?
19 REPLIES 19
could you please post a screenshot of the radio#1 GUI settings for such a AP.
Dennis
New Contributor II
Although channel width is set to 40Mhz the bitrate on some APs is 1.7Gb/s. The only difference I can see between these APs and the ones showing 800Mb/s is that on the 1.7Gb/s APs the setting "Active OBSS channel width adjustment" is enabled.
Dennis
New Contributor II
I can confirm 40Mhz channel width and SGI.
Dennis
Are you running 40Mhz wide channel with SGI, then this is correct, check the data rates in this table: http://mcsindex.com/
-Gareth
Dennis
New Contributor II
Thank you. Showing:
Bit Rate:800 Mb/s Tx-Power:18 dBm
